Frame/bracket - Tig Welding
Tim
Active member
Hello Guys,
I have a couple of brackets that I want to tig weld to the frame. What do you have to do to protect the electronics - just disconnect the battery and located the tig ground as close to the weld as possible?
Thanks
I used to just remove the battery ground but now i believe you must remove all grounds. I have killed 2 spark boxes from welding on the frame with just the battery ground removed. The first one was a MSD box ... it misteriously quit working a couple of days after doing some welding ... thought it was just coincidence. A year later i was doing more welding and a couple days later my Jacabs spark box just quit working ... so be carefull when welding and remove all grounds.
Thanks for posting this. A buddy had an MSD spark box go bad after some welding had been done on his car. After trying a few things, he gave up on the MSD unit and went to a Mallory. It may have just been the welding that did his box in. I sent him a link to this thread.
