I have found play in the splines on some spindles and flanges. Turning the wheel CW then CCW causes a "lash" and you can feel the movement. I would look at the spindle splines by removing the spindle flange. Eye ball the splines from the end to make sure they are not twisting. Import spindles have issues.
Thanks for your input, Well I have the new flanges on and everything is good. The spindles are in good shape for being the originals plus the U joints are new.
After having the front end aligned while the vette was out of service it now tracks straight. But there is play in the steering and on the highway it wants to wander so I will now change the steering box to a power box getting rid of the old system.
Yeh, if you can get the correct Jeep box, I fail to see why a plate over the frame on the outside, and using the same 4 bolt mounting that Jeeps used, wouldn't work for us, I dunno why Borgeson mods the boxes to fit our 3 bolt mounting pattern....say 1/8" steel square, mark, drill off the box, position the box drill frame, bolt it up.....:gurney:
having said that, I put in a rack about 11 years ago, works fine, ....:devil:
