Fog light set up help.
Shirley1978
California, San Jose
so i want to put in these fog lights.
http://store.summitracing.com/partdetail.asp?part=HLA-H13750621&view=1&N=700+150+
more for looks really... might not be legal but i really could care less..
theres a pdf with instructions on how to wire them in.. im a total nOOB when it comes to electrical shit, so im coming to you guys...
i want to be able to turn them on and off from inside the car. i beleive they come with a switch. im thinking about doing the last one on the instructions, the off road use only.
http://static.summitracing.com/global/images/instructions/hla-h13750621.pdf
so what wires should i attach this to? also, what would be the best way to get the switch into the car?
just trying to do my homework before i buy anything..
thanks..
Jonny
COuple of easy ways to get the wires to the interior. The speedo cable has a grommet where it goes thru the firewall. Just poke a hole in that. THere are also a couple other places with vacuum lines that could also be used. Pick the one you like. Get the power for the lights from the wiring junction on the left fender just outboard of the master cylinder. That will feed the relay, just put a fuse inline. The control wiring can be picked up a couple different places- either at the headlight switch or from the forward light harness under the hood.
