Yes mate and I read it over a few times but it said "Allow 60 minutes dry time before applying additional primer surfacers and/or topcoats"Do you have the tech sheet for your epoxy ?? I had to wait 12 hrs before spraying primer over the epoxy. I remember that specifically because I wanted to spray the epoxy and the high build urethane primer the same day.
Well, I wore a mask and shorts and T shirt. :mobeer:Should wear protective suit to. I had a friend get really sick from paint chemical entering his skin.
Hehehe, I still went and re-read the data sheet and looked at the car and made sure the primer hadn't all fried up after you asked that Karsten! It was still ok though...Yes mate and I read it over a few times but it said "Allow 60 minutes dry time before applying additional primer surfacers and/or topcoats"
:thumbs: :thumbs:
looking good!
say, do you have any other pics on how you build your custom spray booth!?
i'll be painting my 68 in the next few weeks after i give it a fine sanding and blow out all the dust out of the garage. i then plan on doing the same as you with the plastic.
thanks
joe
