MYBAD79
Moderator
There have been quiet a few threads about aftermarket fiberglass springs and associated ride height problems. It seems that the TRW style spring is the worst when it comes to ride height, VBP springs seem to be close to stock height but sometimes requires 8" long bolts (stock 6").
Aftermarket or re-arched steel springs can also raise the vehicle to almost 30" (ground to fender lip), stock ride height is 26"-27".
Share your experience here, if you have photos that's even better.
Here's a very old pic of my '79: aftermarket 9-leaf steel spring with stock 6" bolts. Ride height was at a whooping 30".
I dropped the car using 8" bolts. It was still at 28" so I bought 10" bolts from www.mcmastercarr.com --- since then I installed a 7-leaf spring that works fine with 8" bolts.
It also appears than height differences from left to right are not unusual. before you adjust the left and right spring bolts to compensate for the ride height check your body mount cushions, they might be deteriorated and let the body sit uneven.
Offsets left/right have also been reported very often. While this has nothing to do with the spring it becomes more apparent when the car is lowered and the tire is close to the fender - again, the body can be moved left/right after you loosen the body mounts.
