MYBAD79
Moderator
These are 2" flares without the mudflaps that I bought from Vanacor. I thought I posted this info before but couldn't find it when I was looking for it tonight... so here we go:
.narrower at the bottom but wider at the top.... shows more tire than the stock fender but covers it at the top. very cool
This is a 295-50-15 tire on the stock aluminum rim with a 2" spacer and the stock fender:
I cut a section from the new quarter to make it fit like the L88 flares - there was no reason to cut out the stock quarter. While the flare was clamped into place I drilled holes for self tapping screws (needed during final install)
after dry fitting I sanded the mating surfaces with 60 grit
covered both pieces with Evercoat SMC adhesive:
Glued in place and bolted to the stock quarter with above mentioned self tapping screws:
Fiberglass putty/body filler:
more filler:
First coat of primer. Note the high spots around the fender radius
Sanded the high spots down:
Last coat of primer after wetsanding. The panel is still wet, looks like clearcoat...
Two years later with fresh paint:
:thumbs::trumpet::thumbs::trumpet::bump:
more filler:
