Exhaust x-over
big2bird
Anaheim, Ca.
What is a good way to permanently block the exhaust cross over passage? Alum intake,BBC, don't care about reversing the process.:flash:
Epoxy an aluminium slug in there. Even better would be to weld and then reface the surface with a belt sander. Like this:
I like that. I think I would even set it back 1/4" to not mess with the contact area. I see no harm with that. I'll try to find someone to heliarc it today. Thanks.:1st:
Ahhh....do it the easy quick way, Plaster of Paris...olde tyme hotrodders trick, surprised you dunno that.....
just fill the passage with the Plaster, let it harden, then clean it up a bit, and put in place.....the exhaust gasses will NOT burn it....anything else they may well burn through....
:eek::thumbs:
:eek::thumbs:
I did know that. Darrow used that method. Just checking for the best. Not my $$.:nuts:
Thanks Marck. $50.
Glen, I got us an artist that welds everything, including cast iron. Just not pot metal.
Thanks Marck. $50.
Yea, that is pretty.
The young 4 wheel drive dudes, by the shop are "artist": too.:quote:
Man, they make MY welding look ugly.:skeptic:
Between the two we might be able to get some good welding.:toothbrush:
