mrvette
Phantom of the Opera
350 SBC roller or early block, there seems to be some strange action in the dizzy mount via the oiling passages to at least the lifters....
in the past I have never had troubles priming a engine with a drill in the dizzy hole and so to load up the pushrods to dripping.....but
they were not any SBC engines....so last years we were priming a SBC engine in a boat, and the drivers? side never dripped oil....Eric swore he saw a bunch of oil flowing around the screwdriver tip and so one side was not dripping on the rockers....so we installed the dizzy and everything was fine.....so we thought....so the boat ran fine for some 4-5 trips out....salt water cooled, and of course Mercruiser....
so, this last trip when the engine blew, my welder buddy saw some mainly AIR and oil puffing out of the dizzy base when engine not running well, but then something happened and it smoothed out and stopped the oil spitting, since it was running decent, they continued on out the ocean inlet and out at sea, they had the engine running fine in flat water, then went to trolling speed and after a couple hours the engine quit and locked up tight....
the destruction was complete and total, brand new engine, and NO clue except one of the center exhaust valves like cyl 5 was bent over and broken off the stem in place with nothing looking bad in the spring/retainer/keeper department....
the gaskets in the exhaust manifolds looked fine, not evidence of drinking cooling water down the exhause into the heads.....
hole in the cyl wall, piston is 50 chunks, valve cut in 1/2 on the parts coming outta the pan....hole in pan,
so boat towed and nearly 3 weeks before final tear down....and of course by then it didn't matter anyway, the damage was terminal rust or not....
so does anyone have ANY CLUE what happened???? anything???
the oil was checked previous to ALL outings, and so it looked good, the engine flushed out and drained completely of ALL water when put to bed....so WTF happened???
not only expensive, but the engine builder eating the whole damn thing now...but we need a clue as this is the 4-5th time that engine coming over that fucking transom and I getting tired of it.....I have the only hook with concrete drive and no homeowners assn to sweat over.....so I get elected....
anyone, any clues???
we going to name the boat it's MY choice, Eric the owner got NO sayso over it....the new name is
PARIAH.....
:crap:
PARIAH.....
