molested84
Active member
Hey guys, here's what I came up with while trying to add a remote system to my 84. I ordered this 9-function control unit from Gama Electronics. John(owner), is a car guy as well and is currently restoring a 1957 Buick convertible.
I went to the junkyard and pulled 4 GM express-down relays @$3.99 each (plus it was 30% off that day). You can find these behind the driver's door panel on various mid to late 90's Pontiacs, Oldsmobiles and Buicks. Part number is 25614182.
The receiver is thin enough that I can sneak it in on top of the glove box and still have easy access should I need to make any changes. In case you're wondering, that thing on the left is a garage door opener from a '98 Buick Park Avenue.
So, now I have both express-down and express-up windows using either the console switches or the remote. I also have it wired where one button on the remote will trigger the door lock relay and roll both windows up at the same time.
If you just want to add the express-down feature to your ride. Here is the factory wiring diagram.
And here's how I wired it to get express up and down.
This one shows a little more detail of the relay.
Cheers, Dave
Cheers, Dave
