Distributer measurements
guru
It appears that my stock delco distributer is 7" tall and 5" around.
What would the measurements of a HEI distributer be?
Sounds like you have a HEI right there now....5" round is correct for the aluminum base....you have a terminal in center of the cap?? if not, there is a coil in there....the cap has a nub off one side, clockwise from that nub with the connections in the bottom is #1 plug wire....
Nope Delco Points distributer.
I was measuring rather crudely with a square.
The "small cap" HEI that has the separate coil (coil not in the cap) is about 7 inches tall and 4 inches in diameter.
