Cutting tires
big2bird
Anaheim, Ca.
One of our crew wrapped a flat tire around his motorhome axle. What is the best way to cut 4-5 wraps of steel belted tire off the diffy?
Oh Lord, all of my life's problems are now put back into perspective.....Really!
:crap:
Two oxy/acetylene torches---one to cut, the other with just the oxygen hose in your mouth...?
I don't think the diamond will last long through that rubber, I"d use the usual black cut off wheel...but yes the side cutter....
maybe a sawzall??
How did this get wrapped???
:bonkers::goodnight:
Cutoff wheel for the belts. Watch for the brake lines.
And be careful- those little steel wires in the belts are double sharp when cut.
