V-Twin
- Joined
- Mar 23, 2008
- Messages
- 148
- Reaction score
- 0
To convert a regular dual point, unilite or magnetic breakerless distributor to a flat cap/crab cap you will need the cap (mallory # 221)
However, you'll soon realize that the contacts inside the cap are placed on a larger diameter circle than the ordinary cap, so you will need:
Mallory # 318 Crab Style Mallory Flathead Rotor, 5/8" Shaft
This will fit the normal shaft, if for some reson you have the smaller shaft, they have one for that size also.
Then you will need to machine the distributor because the housing OD is larger than the cap ID.
After this is done, the cap will fit but the straps are way too long. You can then either fabricate some clamps or buy a strap kit. I have a set of fabricated clamps on there now, still waiting on the straps to get here.
The crab style cap gives a clean finish and a lot of added room there.
