Compression tester
Worship79
The Netherlands
Who is using what compression tester and why? Looking for a easy to use, not to expensive tester to do basic compression check.
I have a fairly good Snap On one that I got fairly cheep on eBay. Still more expensive than a store brand model. but I work under the thery that if I'm bothering to measure something, I want the measurement to be accurate.
I also have a Snap On leak down tester. Between the two, I can diagnose a mechanical cylinder/piston/valve issue pretty quickly.
