SmokinBBC
So after the discussion in my sidegapping thread, I decided to check my ignition set-up this morning.
When checking the stock replacement AC Delco coil, I came accross 2.0ohms resitance on the primary side and 11.0 k ohm resistance on the secondary side. Bench tested without running it today.
Secondary is within all specs that I can find. But I ran accross a couple of different specs for the primary...which of course is confusing:
Corvette shop manual: .35 to .55 ohms primary at 75 degrees (room temp)
MSD Blaster 2: .7 primary 4.7k secondary(comes with a .8 ballast resister to increase the primary value to 1.5?) direct repalcement
Accel Super stock: 1.2 primary and 8.7k secondary....Direct repacement
So what is the correct primary value? Based on the all the info, it looks to me like the shop manual is outta whack with the rest of the info.
Also, the accel and msd repacement coils are much cheaper than the AC Delco replacement...what's up with this? Asian coils?
