Update :
After a lot of talking and searching, here's the results so far.
1)here's a lot of stuff you have to prevent on a car system if you want to make it right :
-Voltage spikes, up to 50v
-Voltage reverse
-Voltage variations
Plus on the led side, a open circuit detection, to prevent domino effect when one led burn.
Dunno if I'll fit all the bill, but I'll tried.
2)I would simplify my schema if I make the driving and the brake light a simple group of led than would be drivent a different intensity depending of the case.
But I'm concerned about the aesthetic aspect.
My led have a very narrow beam that draw a distinct pattern on the bubble cover
(pics for last year experiment, the center part was not implemented)
So I would be loosing the wow factor led are also about.
3)There is a lot of existing automotive IC solutions, from several chip maker, but it's not for the retail market, got to buy by the hundrens.
I may ask for sample... why do I fell it's like cheating to the DIY philosophy?
4)There is a lot of preassembled current drivers board, for the home ligthing and led maglite market. They're robust, tiny, and dirt cheap 2.20 w/shipping:
http://www.dealextreme.com/p/mr16-1...egulated-led-driver-8-40v-input-13553?item=34
They are pretty much the default impletementation of this chip :
PT4115
They can be hooked to a PWM signal too.
