Hello there everybody. This is some progress on my CFI to Carb conversion. Ok so far I have replaced the engine with a new 290HP GM crate engine. I installed some of the wiring for the lock up kit from Bowtie overdrive the one that comes with the brake switch.
http://www.bowtieoverdrives.com/cata...php?ITEMID=332
Old CFI
New engine
I still have to remove all of the wiring from the CFI and figure out what goes where as far as Vacuum lines and stuff. I will update as I go thanks.
NANCY
Part list that I have recived:
MSD-35599 WIRE SET
MSD 8361 PRO BILLET DISTRIBUTOR w/vac advance
MSD 6200 IGNITION BOX
MSD-8207 STREET BLASTER SS COIL/E-CORE
NAL-12499529 GMPP 350 LONG BLOCK 290/32
HLY-0-80670 CARBURETOR 670CFM
ARP-430-3102 MOTOR MOUNT BOLT KIT STAINLESS
EDL-2101 MANIFOLD PERFORMER SBC NON-EGR
EDL-7201 INTAKE GASKET
EDL-8504 BOLT KIT INTAKE MANIFOLD
FEL-35062 GASKET
GTR-61047 CURVED RADIATOR HOSE
GTR-61163 CURVED RADIATOR HOSE
HED-68300 (CA) HEADER
HLY-20-121 700R4 KICKDOWN BRACKET
HLY-20-95 KICKDOWN BRACKET TH-700R4/4L60
MAA-4309 FUEL REGULATOR THREE PORT COMP
MRG-1272 OIL FILTER ADAPTER
PTP-7-504 GM MTR MNT TYPE A SHORT PAIR
SUM-161358 BALANCER OEM 350 8 INCH
SUM-371101 ALUM 90 DEG SWIVEL WATERNECK
SUM-G100SFI FLEXPLATE CHEV SFI 168 TOOTH
SUM-G1438 OIL PRESSURE SHUT-OFF SWITCH
SUM-G1571HS SHRT WATER PMP BLT KIT HEX SBC
Old CFI
New engine
NANCY
MSD-35599 WIRE SET
FEL-35062 GASKET
