mrvette
Phantom of the Opera
A co-worker has a Jackson setup on his 383; the whine is very subdued--just enough to let you know it's there.
and if you get the quiet version, check the clearances carefully, and use a molly assembly lube durring the assembly, process, youll find that after a few thousand miles the sound levels dropped off too almost un-noticable, in fact unless its spinning up about 6000 rpm its almost not decernable
I was told the knock sensors do not react well with gear drives....so did not use one on my engine....sold it to GURU some time ago....
but now there are quiet ones that maybe good to use??
cost and availability....???
:chinese::flash:
