kwplot34
Heart Attack
Yes my bad on the .540 that is not at .5 sorry about that.
I would think that you mean that your valve lift with 1.6 ratio rockers is .510" ????
With stock 1.5 ratio rockers the valve lift would be .506"
Again: a stroker SB with that cam and 11:1CR should have a lot of power off idle... just for shitz and grins I'd put a stock HEI dizzy with vacuum advance on there, check and adjust timing and see how it runs.
I think i have probably caused confusion with my bad typing,the lift on my cam is .540,and i have 1.6 ratio rockers.My bad for messing that up.
I just think it should have more off idle,but i could be wrong,we will get it looked into next week :bump:
Yeah Bird,me being crazy and needing more ponies are 2 totaly diffrent subjects.
But on a brighter note i was in the garage checking my plugs and dizzy and guess what i found :twitch: one of springs was off on the mech advance,that could cause a problem on the low end all of the timming comming in instantly.
I will test drive it tommorow,i have one neighbor that has complained about me running my car late at night :cussing::cussing: He actually walked a good 200yds or more and came up my drive way and bitched me out. Damm city people need to go back where they came from :skeptic:
