69427
Amongst other things, I'm kicking around doing a different CAI setup for the '84. I presently have a cowl induction setup on it, and while it seems to work okay, I have to think that the laid back C4 windshield (compared to the '69) has to be affecting the efficiency (ie: pressure buildup) of this system. So, I'm kicking around getting the air from the radiator plenum. The concept is simple, but the difficulty is radiator to hood clearance and materials choice. I'm starting out with a swap meet C5 part below.
I may eventually have to do some cutting of the underhood structure to clear this, but meanwhile I'm going to try to change the contour of the air bridge by heating and reshaping the bottom edge so that I can make it sit a little lower/flatter. Another thing is I need some sort of 45* elbow (3.5" OD) to attach to the front of the bridge to be the "snorkle" that directs some air out of the plenum.
I think the easy part will be the tube that runs from the bridge back to the airbox.
