C4 suspension measurement needed
JeffP1167
Yucaipa, CA.
I need a accurate measurement of a (stock ride height 88-96) C4. What I need is the distance from the center of the lower shock mount to top of the lower upper shock bushing (where it sits pressed against the bottom of the upper shock mount)
Basically need this to make solid rod so I can remove my mono-spring and simulate actual ride height (like if car was on level ground and suspension settled with full weight)
I still have my '87 vette manuals, and can look it up, but unsure of any whatever changes they made....you did spec 88+......
PM me to make sure I dont miss the thread....
Need 88 up because I thing the lower shock mount is different on a pre88 and might change the ride height measurement I need.
