69427
Making slow progress on getting the C4 batwing modified to put on the '69. This batwing is about 7 pounds lighter than the C3 batwing currently on the car. Here's the (not yet finished) adapter ring (3/4" aluminum), and the batwing has been drilled out for the C3 pattern. Still need to weld up a couple of the original C4 bolt holes.
I need to narrow the batwing 2 1/4 inches to clear the narrowed C4 suspension in the car. I grabbed a bunch of old steel remnants and welded up a temporary jig to hold the outer mounts in place while I cut the batwing and reposition the mounts inward 1 1/8 inch. Not seen in the picture, but I used the threaded holes at the outer mounts that would otherwise hold the dampening weights.
Here's the outer mount moved inward 1 1/8 inch. I now need to clean up the cut and start welding the pieces back together.
The adapter ring is 36 ounces (additional weight), and the stock C4 spring bracket is about a pound lighter than the steel adapter bracket I currently have on the car (to be able to use the '84 Z51 spring). I should be able to lose an additional pound or two by now being able to use the toe mounts cast into the C4 cover, rather than the steel adapter bracket I had to fabricate to attach toe links to a C3 cover. I might also be able to use shorter/lighter spring hanger bolts with this batwing (won't know until later). All in all I'm looking for about a seven pound net weight reduction off the car. The reduction is down low and way back unfortunately, but it's still mass that won't be there needing to be accelerated and decelerated.
