SuperBuickGuy
I`m curious, how does anyone know which taller Howe ball joints are the best to use, they make a few different lengths?
That I curious about is what it would take for a machine shop to make a stem extender?? screw the joint into a tapered rod assy, use LOCKtite Red on the threads, and have the new rod fit into the control arm?? how simple is THAT?....NO? why not??:evil:
the extended, tested, ball joints are $85.00 each - so 170 a pair.... automotive machinists are not easy to come by up here, so I'd expect to be charged at least that to have some machined out (here's where it'd be great to have someone volunteer to teach me how to do inside taper joints on my enco lathe :huh:
It took me a while with some leads from other shops, but I finally located a shop here that had the correct taper tools to make a adapter for my rack to the stock tie rod ends....and of course adapted/fit perfectly, I would much rather have stock tie rod ends than the aftermarket heim joints most guys use....street durability and so to be easy greased....
and too boot I didn't have to buy/wait for heim joints...
:thumbs:
the circle track guys (roundy-round guys) have access to a taper tool that works slick for modifying spindles and tie rod ends to the right angle
