Battery kill switch
That should do just fine - watch your amperage and use properly sized wires. We have a dozen or so on the boat for isolating loads.
Don't open it with the alternator running - you'll most likely blow the alternator!
That one is rated at 150 Amps - just how much will you run through it depends;
On the alternator size; the regulator and its charging scheme; the depth of discharge of the battery when charging; temperature; etc.
Blue Sea has made those for a while. They have a calculator that might help:
http://beta.circuitwizard.bluesea.com/#
I'd use 3-5% voltage drop and check your wire for its thermal rating.
A little easier chart can be found Google ABYC Wiring Standards. Heaps of helpful ideas.
Be safe!
edit:
http://www.acbsphl.org/Tips_and_hints/ABYC_Wiring.htm
ABYC CHARTS ON THIS PAGE
I'm using the switch that mounts directly at the battery terminal, most vendors and local parts stores sell these... it's been about 4 years, so far so good... no problems....
I have installed this, very handy and no issues.....using a wooden block to adapt the switch. I operate the switch from my driving position.
Arne
