JeffP1167
Going to start this project soon and have never done it.
No pics but it's very easy. Remove the dust seals and the pistons come out. Just replace the square o ring and dust seal. Clean piston, use caliper assy lube to put it back together. Pressurized air is the easiest way to pop out the pistons. These calipers are super easy to do.
Make sure you thoroughly clean the caliper bores and passages with brake cleaner and air.
Do yourself a favor and get a late master with 1 reservoir. All mine with split reservoirs have fluid transition filling one and emptying the other, necessitating scooping fluid back in the other every now and then. Rockauto is probably cheapest. Rebuilding is a matter of removing the circlip, taking out the guts, replace seals and put bsck together if bore is smooth and clean. Don't break off the prop valve and warning switch when removing. Bench bleed before install
