Aluminum lug nuts
Fuelie74
Monroe, WI
The other day I had the pleasure of installing aluminum lug nuts on a customers car at work. Up till then I had never seen a set before, so that got me wondering just how safe are they? I understand the benefits of reducing unsprung weight, but fear loosing a wheel. Does anyone have any experiences with them?
Whilst this is not relative to the big V-8's, Triumph Dolomites were all fitted with alloy lug nuts to homologate them for the rally cars. Rally is a BIG deal in Europe!
I suspect they tossed them at every stop to save the few grams of unsprung weight that a racer would covet.
For a street car????? Are you barkin' mad!:tomato:
I don't think I seen 1/2 dzn aluminum nutz/bolts in my life, for freeking NOTHING, let alone a lug nut.....
that strikes me as stupid....along with torquing lug nutz on a aluminum wheel to 100 ft lbs....and see the wheels all mashed and deformed, which has to introduce stress breaks into any casting.....
I have always torqued to 5 taps on the Ingersol 1/2 impace at 125 psi....
it seems to equate to about 70 ft lbs....
put 70 ft lbs on a aluminum nut, can you imagine thread distortion??
bet they say to not reuse them....
:suicide::stirpot:
So it looks like I am not the only one with a gut feeling that they are not a good idea. I was thinking maybe I was being over paranoid, but maybe not.
Ford uses aluminum wheel studs on its mid size cars. I thought C4s did too.
Post Retraction
The above statement is in error:sweat:
The Ford Taurus used Aluminum lug nuts not studs.
I did a web search and found no US made auto using
Aluminum Studs.
Please forgive my error:flash:
I searched too and found that there is a lot of discussion across the internet on this topic.... I don't think I'd trust aluminum lug nuts although even Summit/Jegs sell these without any warning that they're for off road only.... they even have red anodized lug nuts that look very pretty :D
UHHhumm...they can paint them thing purble with pink center, and harden them with poly unobtanium.....
and guess what?? I will use greased steel.....
:quote::censored:
