I have used the L-79 cam in a few engines with 9.5 cr. I works pretty good with this ratio. Of course 11.1 was what was used in the 60s, but still will work with 9.5. Down about 25 to 35 horse from 11.1 but will work with proper tuning.
ush:
I am not doubting it's a good cam , I just don't think that a stock L48 bottom with stock low cr pistons and 58cc heads are enough to support a hot cam like this one....
The cast bottom end dictates a red line of 6000 or less (if you don't want it to self destruct)...
this cam is no good if your redline is 6000... use a lower duration cam that is more geared towards low end power, like a RV cam.... let it pull off idle and stop at 5500rpm.... with a TH350 that's as good as it gets.... if you want the engine to go up to 7000 and still make power you need good heads and a good cam/intake... AND.. you need a better bottom end (forged crank/rods/pistons).... rpm is what kills engines/cranks, not only HP.... a manual (stick) tranny would be advisable too....
