A-Arm Cross Shaft Dimensions - Suspension Gurus
CrossedFlags77
Active member
I have a favor to ask. If anyone has their front suspension apart, can you take measurements of the upper a-arm cross shaft. I have access to a lathe and mill so I want to make some aluminum shafts.
Also if there are different dimensions or offsets that would aid in a better camber curve I would be all ears to hear it. :drink:
I have some I could measure. I sure would consider making them out of steel. There is not that much weight saved with aluminum and not much opportunity to beef the part up by making it larger.
