JeffP1167
How does thus get read as like a troubled codes or does it need to go to Chevy?
I've had that light one a few years ago on my Z28.... took the car up to 70-80mph and slammed on the brakes.... ABS worked just fine ....
I cleaned the sensors and that fixed it .... did you try that ???
Corrosion between the wheel bearing and sensor is a very common problem that normally results in a low speed activation and no codes so that probably isn't the problem. You need to have the code pulled with a factory level scan tool. Most auto shops will have a scan tool that will do that with your Camaro.
Sent from my SCH-I500 using Tapatalk 2
