saudivette
Clueless In Sandland
I want to get a new gas tank sender unit for my 82 and see that there's 78 - 81 types and then 82. What's the difference between the 81 and 82 tank sender unit?
No, I want to modify the filler neck and thought I'd buy a second one before I started messing with it.
I no longer have the Crossfire so can I get away with an 81 sender unit? They're quite a bit cheaper than the 82 unit...
Yes, but if your in tank pump is still there you're sucking through it, not such a good idea. Better would be to keep the in tank pump and run it off a timed relay switched by ignition (priming the fuel pump) and constant feeding it off the oil pressure switch. You have the oil pressure switch on the back iof the engine, the big black thing with rubber boot. Also provides signal for the oil press. gauge.
Then you can regulate the fuel pressure down and use the stock return line, always plenty of cool fuel, no vapor lock ever.
