damoroso
Okay, been busy, thought some of you might be interested. First off, I have a bone stock 81, with now about 70K on it. But as we all know, the cars weren't exactly over powered. There are certainly several ways to increase the power of the existing engines, but I've always wanted a big block vette and love the 80-82 body style so I thought I'd build a big block for my car.
The engine is a 402 punched .030 making it about a 409. Its running 10:1 comp with a strong cam that pulls from 1800-6500. I degreed it 6 degrees so it should pull a bit sooner. I also had larger valves put in the heads and had the ports cleaned up a bit so it'll breathe better. I'll be using the 81 E4ME because I like Qjets and think they're just miss-understood critters. I contacted Cliff Ruggles and he made me a customized rebuild kit for it and showed me what to use in his book to make this carb work with the BB. I'll also be running a serpentine set up, fit from a small block adapted to the BB. I'll run an aluminum radiator with dual electric fans to keep it cool.
Well, a big block and a TH350 don't go so well together so I needed a transmission for it. There are certainly several ways to go, but for all things considered, I choose the 2004R route. I'll be keeping the rear end with the stock gears for awhile, and I like the gearing of the 2004R compared to say the 700. The car is to be built to be able to be a daily driver and to take on long trips, so the gearing is important and with the torque the engine should have, it still shouldn't have a problem leaving stop lights.
I've never built an automatic trans before so this was fun. I used parts and a book from CK Performance in New York. Chris has been very helpful and I've added things like billet parts, a coupe extra clutch discs, some servo and valve body work and a little machine work like adding holes for cooling and such. Chris built a custom torque converter for the car, it's a 10 inch and has a stall speed of 2800rpm, but according to Chris will have very street able manners. (A good thing cause I'm sure I could pop the rear end with this set up if I really wanted to!!)
So, the engine is built, the trans is built, and it's time to put them in the car. I didn't want to put a new engine and trans in at the same time as this is my firs trans and with the cam break in procedure, that's too much for my nerves!!! :sweat: So, I thought I'd put the trans behind the stock 350 to check it out.
Anyone who says the 2004R is a bolt in isn't exactly telling the truth. Yep the trans bolts right up to the engine, and the speedo cable screws in, but...the trans mount is 7 inches farther back than the TH350. Not too big a deal, you can buy a cross member for about $200 from several places, or you can modify the one that’s in the car. That's what I'm doing this week. Also, the shift cable mounting bracket won't fit, it has to be modified. The cooling lines are close, but depending on your car, you might have some work to do. And the 200 is a heavy SOB! That and I'm definitely getting older!!
I should have the trans in and complete by the weekend, I'll post and let everyone know how it turns out. Then it's engine time....
Needless to say, I'll have a bunch of stock 81 parts I won't be needing, so if anyone is interested, let me know!!
