Vynlerules
New member
- Joined
- May 23, 2013
- Messages
- 4
Being from Australia, for registration purposes, :confused, do I need to have amber rear indicators if the car is over 35 years old?
Bob
Bob
Putting a manually activated valve on the hot water lines is a common mod to ensure cold blowing air. The vaccum activated valve seem to never shut off correctly....and the there is not enough to close the hot water shut of valve.
all you really need to get it registered is the windscreen demister working .
for the other stuff you have to check the whole vacuum system to see if theres a leak somewhere.
both headlights should rise quickly and at the same time as well.
my 77 was the same but i never had trouble with water , i suppose if you squirted a hose in there it might be bad for it
if your in Perth PM me your number if you want
Barry
