Nipa
Member
My -71 SB wasn't too bad when started but it came from Michigan and there was a lot of surface rust on the frame I decided to check it out. The mileage was stated to be original 36k but doesn't matter to me. I plan to drive it lot more (even if it was 136k)
(the method of lifting the body looks kinda radical but nothing was damaged. Hopefully)
Finally got the body separated from the frame.
Found what was left from tanksticker
Nothing serious in the frame. Had it sandblasted and painted with 2 coats of POR-15 and 2 coats of POR-15 chassis black. Also sprayed rust-preventive coating inside the frame. This is actually the situation now. Now I have spend weeks in restoring all the other components. Have also the carpet set ready to be installed. Painting will happen sometime later.
