57 Chev PS pump pressure, anybody know?
big2bird
Anaheim, Ca.
Anybody know the steering pump pressure for a stock 57 Chevy? I know C-3's are 1,000PSI, and Chevy trucks from that period were 1,500PSI. I ASSUME, since a 57 is controlled just like a C-3, it's 1,000PSI.
Bird, I have no direct knowledge but from comments I have seen in the past, it's the same system, essentially....
maybe check with Jim Shea over 'there'....
OH, to edit....when I put the serpentine '88 vette pump on front of my then dead stock L38 engine, the entire pump valve was changed to the '72 design as I was told the pressures/flows were different somehow....I forget which....so I did and it worked fine for years....leaked like the all do, but nothing abnormal....
but with that valving difference in the pump right now....I really dunno why I am happy with the rack install I did some 5-6 years later, the road feel is fine IMO....against some other complaints....
Does the 57 have the hydraulic cylinder assist like an early Corvette or a servo on the gear? Generally, I think the cylinder style take less pressure.
I have a GM Power Steering and Pump service manual from 1975. It has the following information:
Chevrolet (except Vega, Monza and Corvette), Buick (except Skyhawk), Oldsmobile (except Starfire) and Pontiac (except Astre): 1350-1450psi
Cadillac 1425-1475psi
Vega, Monza, Astre, Starfire and Skyhawk 750-850psi
10-20 Series Vans, Corvette 900-1000psi
10-20-30 C & K Series Trucks 1200-1300psi
57 used the same valve/ram set up like the Vette. Yes, the C-3 steering dates back to 1955.
I ASSUME at this point like you, it's 1,000PSI.
So I have to assume that is what my '88 serp vette pump is doing, as I just replaced the valving with the OEM stuff out of my '72 pump, it also changed over to the flare fitting, instead of that O ring AN style.....
so keeping that OE '72 valving reduced the line pressures/whatever it did with flow, I dunno....but that's into both my HB and rack steering....
which most certainly was meant for higher pressures/flow?.....
maybe explain why I find the feel to be just fine on my car while other don't....
:bonkers::crap:
