37 ford after market turn signal indicator and wiring harness conflict
bobs77vet
arlington va
hi guys well time to make friends with the wiring on the 37 ford and to put it simply the existing wiring harness is terrible its a 12v system and i will be adding an additional aftermarket headlight switch, horn button and column mounted turn signal indicator and new wiring harness. before i order this stuff i want to make sure that they are compatible..i have squared away ballast resistor circuit and starter switche, etc. however i am having problems figuring out the after market turn signal indicator with hazard flasher (speedway part 910-62860)wiring with the Mr roadster 12 circuit economy wiring with two flashers (speedway part 910-64017)......everythng lines up between the two except for the flasher hook ups....the turn signal indicator uses one flasher and the Mr roadster harness has two flashers ....how do i reconcile these? what i am looking for is a wiring harness set up for the after market turn signal indicator thks bob
