1971 Corvette Exhaust Panel Dimensions Help.
Bad Bird
Newcastle, Australia
Good evening all.
The exhaust panel on my car was filled in for side pipes. Since these are generally illegal on street cars in Australia, the previous owner had some tailpipes fitted. Instead of fitting the correct '71 bezels and tips, he just roughly cut out the filled in panel. See:
When the panel was filled in, the bonding strips were also ground down and patched to the point that I can't tell where I need to cut to fit the bezels. Could anyone with a 71 (or similar) Corvette please be able to measure the following dimensions for me? The bezels that I have after Corvette Central aftermarkets, so if anyone can measure the width of their bezels (dimension 'C') that would also be great!
Best regards,
Matt.
On my 70, c looks to be 8 1/2 inches. I can get under and check the size of the cutout for c if you need it.
