I have a oil leak on the front of my zz4.
I have not quite found exactly were the oil is coming from.
I have replaced the pan gasket and the stock timing chain cover with a new zz4 timing chain cover still have a leak.
The oil looks like it is coming fron the pan gasket under the timing chain cover.
What is the secret for the pan gasket
This is not the first time I have replaced the pan gasket I installe d a new cam and installed a new fel pro pan gasket then thats is when I got the oil leak this gasket I glued on with rtv and still had a leak.
