Upper Radiator Hose on a LT1
Does anyone have some pictures of the upper radiator hose setup on a LT1? I am specifically interested in the hose to thermostat housing/intake area.
THE largest reason I went with a LT induction was simplicity, a one time modification fight with the manifold to do things right with the HEI in normal install, and the water fittings in a more normal flow pattern....and like the other day, it's SO much easier to work with...that TPI has been a PIA for some 13 years....tired of it....tired of the dated look too...
:tomato:
LT-1 or LT1?
If you mean the EFI motor, it's on the water pump:
I'm looking for a thermostat housing with the tube connection coming straight out the front. I can't use the swivel type because I don't have enough room (height).
