Did some more. Fixed the rust holes in front of the door and redid the seams there and to the front (inner fender)
This will be my elbow hookup, have to fab the elbow and weld it to this plate.
Painted the cowl area and reinstalled the cowl screen and wipers
Wired up this harness with a tail light converter to get 4 red stop/turn lights. It works fine, until you press the brakes w/ the turn lights on and then it freezes on the side that should blink. This stupid chinese POS is fubar. I'll do it the old fashion way with 3 NC relays pulling 12V off the battery and using the signals just to switch. A little more wiring but I refuse to waste money on crap like this again.
fixed the other side rust, sealed the seams and put bedliner over the entire areas on both sides so it doesn't show as badly that it was repaired and it's now weatherproof.
The rear storage lid does actually close right, I had to guess where the brackets went as I don't have any reference here. Worked out fine
Put the carpet back in, it's starting to look like a car again
I also put a micro switch on the pulldown motor so if someone pops the lock and the trunk opens the alarm will go off. You can see the micro switch on the drivers side next to the nylon linered guide rail. Pressing the 3rd button on my fob will also pop the trunk. LOL it's almost a luxury car
biggest bummer of the day.... that damned Hawks Thirdgen high rise spoiler is crooked. I didn't notice before because the car was on the lift w/ the back close to the workbench. Now that I had it in the clear and stepped away from it I saw it immediately. It stands out like a sore thumb
![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
it's completely unusable, it looks like SH!T!!!!!!!! I contacted hawks, I hope they work with me to make it right as it not only cost a small fortune, shipping was murder too!
See how the drivers side curves off to the rear
Not a happy camper right now!
Fabbed a little mount for the retard box, decided to stick it behind the bumper. not much room in the engine and I didn't want a bulky bracket. I also need the space for some reservoirs and a water to air intercooler
Installed a good chunk of the interior including the nice carpeted console I got from 3rdgenranch (amongst a whole bunch of other parts)
Put together this box, it's missing 1 nc relay, came 1 short so only 1 indicator is working but I'll have a full set tomorrow. This box converts the stock amber turn/red brake lights into 2 turn/brake lights, painted the lenses to suit. Never liked the amber.
W/ lid on, also missing 8 pin connector body, also coming tomorrow (hopefully)
All red vs stock, I like the reds a lot better.
A vid of it working (blinkers on but vid may not have processed right now)
[ame]http://www.youtube.com/watch?v=v5OksxvUW8w[/ame]
Still have to sort out the crank pulley, waiting on some missing bits of the fuel system and still have to mod the cooling system/radiator and hook up the power steering pump.
Been busy w/ the 82 trans am and some other stuff so didn't get a whole lot done.
I did fabricate a small bracket for the power steering reservoir
Added cold air ducting to the SC air filter. Not sure I'm 100% satisfied with it as it is, I'd rather have it rotated to the underside of the filter. Will have to check if there is room. the black piece is simply fabricated from some rolled alu sheet and a 3" alu tube.
Removed it, came to the conclusion that it's an eyesore
I got some sh!t done ... not much but still LOL
My main problem was the crank pulley, the stock one I couldn't use because of the fat belt conversion, a stock serpentine one was too large since i use small pulleys on the wp, so I had to get an underdrive one. Did I mention those are cheaply made Chinese POS things? Damn, what a poor quality. There's chips and craters in them and they wobble too.
Main problem, it's too long, needs 12mm removed to move the grooves back that amount. What to do? I need it to go together wobble free so on the lathe a section was removed and then the last section on both ends was stepped so they interlock, the 2 halves were pressed together and then tig welded (ran out of gas about 90% there on the inside, will have to finish it up after I get me some new gas)
The pulley also lacked the centric recess for the spacer and I didn't want to do without that. The spacer of course was too long too so that one was milled down also
Pulley halves after machining, pressed back together. Took out 12mm.
Centric section machined in
A little welding
On the inside too...the setup w/ the bolt is my quicky rotating fixture for easier welding
With the spacer and SC pulley
it all lines up perfectly now. After welding that last bit it's going to be blasted and powdercoated black again.
Also mounted dial knob for crane retard and a bracket for a 2 bar map sensor
Got my pulley back from the powdercoater and put it together.. it fits like a glove. I'm pretty pleased with the result, small pulleys, plenty of space, looks a ton better than the horrible stock flat belt/v belt combo. It should run a lot better too, no squealing belts anymore. It's a tight fit in there with the KRC power steering pump. With the under-driven crank pulley the WP is still a little overdriven but only a smidgen.
It all lines up straight as an arrow. Now the wait is for my intercooler and bypass valve along with some other neat stuff so I can get moving on this thing again. Been too long w/ too little progress.
I managed to get the radiator setup done, modified and welded the rad to fit a short -20 AN hose.
Also had to mod the rad mount, came out ok
Finished my trans cooler setup, used flex lines from tranny to a bulkhead, then hard lines and then flex lines to a remote filter setup and the cooler. Still need to add lower brackets to the cooler.
![24c435424326ae.jpg 24c435424326ae.jpg](https://www.vettemod.com/data/attachments/26/26823-ff09f667f8d2a821d5be4f74c1455074.jpg)
