...the ZIP Corban will last for 5 to 10 years if exposed to weather, longer if inside frame rails, door structure etc... This stuff will penetrate like you have never seen, coating the smallest areas. When sprayed on the inside of an aircraft fuselage, it will seep thru to the outside around the rivets and Hi-Lock fasteners. I don't think this stuff can be beat for corrosion protection. Just make sure you get the thin AV-8, it is pretty much transparent.
. . .ZIP Corban . . . Just make sure you get the thin AV-8, it is pretty much transparent.
