so an update.edited One thing I appreciate about fiberglass is close is absolutely good enough and a good sign you're overthinking the process
first step... use the old fender as template to get it within 1/4" of where it needs to be
this allows me to determine where the front edge is - once that's determined, it really doesn't matter what the rear-most edge does - well it does, but if it's wrong you're going to have to fix it rather then refitedited
mark
we interrupt this flare with a note that the tank is being a pain lining up and unlike the fiberglass work, it has to be better then close
next step is to cleco the panel on
then drill holes in the flare so that it goes where the old fender fit
and voila
front fender got some work, but I have a long, long ways to go
same method to get it close
and the marker light is hitting the inner fender....edited
ah well, it's closer but back to the back
originally I thought I'd leave this side until I got the other side.... that won't work because I need to fit the rear panel at the same time as the quarters
so chisel out the bondo
heat and separate
I have about the front 10" to finish loosening, and the vertical then it's off.... I was losing patience so it became time to stop
what it looks like from the back
