Looks like you are at 10:1 in first gear. That's the best choce for a street car.
I like it.
I'm running a Richmond 5 spd non-overdrive with a 3.08. I really like the ratios. The .8 overdrive would be a nice compliment. What shifter are you using? I was using a Hurst but switched to a Long. I like it much better.
I bent and shortened mine. I heated the lever just above the mount area and put a rearward bend. I also ground around the top part round to reduce the size enough to cut more threads. After threading I took off close to 3/4". I then used a C3 leather shift boot that covered the shifter box better and fit around the lever better than th stock rubber boot. I still installed the rubber boot underneath and cut it around the shifter box to help keep the heat out.Long but I need to shorten the lever about an inch...:smash:
Thanks but the camera likes the car. It's a 10 footer. :smash:cool...
My car is not that nice looking.... :amazed:
