How much current does the low voltage side of a relay use?
The reason I am wondering is I am installing a eletricly boosted power brake kit and it uses a relay.
I am useing the eletric choke terminal on the carb for the 12 v source for the dual rad fans and I want to use the same 12 v source for the relay on the brake kits relay.
The 12 v source to the carb terminal comes from the fuse panel this will mean there will be 3 relays and the eletric choke on that one fuse do you all think this will be to much and I should find a new key on 12v source for the brake relay?
