BangkokDean
How do you turn on the hazard lights on my 81? I see the switch on the steering column but how does it work? I tried pushing it in but it does not push in?:sos:
Are you pushing the center in ? If I remember right the center pushes in and to turn it off you pull on the outer sleeve.How do you turn on the hazard lights on my 81? I see the switch on the steering column but how does it work? I tried pushing it in but it does not push in?:sos:
Can't be, you push it in, just the inner part not the collar. You pull the collar to disengage the hazards.
