I don't believe AFR is the only company that can offer performance. Yes, I have been considering AFR heads. I have a 350 in my 65. It is a driver, a street car not a race car. I like cars that set you back in the seat when you stomp the gas. I have a Richmond non-overdrive 5 speed with a 3.08 rear. What head, cam, intake and carb size would you recommend to set me back in the seat without breaking the bank?
Thanks
Depends on your criteria. If you decide that AFR is the right head for you, that's terrific, go buy them. I hope you enjoy them and they do everything they can for you and are everything you wanted. All I have ever said is, there's more than one brand on the market, and perhaps once your criteria is identified there may be a better solution. I sincerely appreciate your willingness to at least consider that there are other products. I betcha when you hopped on forums no one ever had the discussion with you that I'm about to have below. They simply told you that if you want to make power go buy AFR and that's all the information you were ever given. Perhaps they even "knew a guy" or something.
Tell ya what, Dart has a fantastic message board. Go there, get their story then come back and ask us if they are feeding you buillshit. Once you are armed with that information, you can make the informed decision. $1500-2000 is a big purchase, check them all out, listen to all their bullshit, ask questions about the line they are feeding you, then decide. Has anyone on another forum ever typed the word Brodix? Dart? Patriot? All Pro? Canfield? anyone? No, you probably asked a question and got one answer.
I lifted this from another forum I post on, Hotrodder's forum:
I did some research on heads and was narrowing in on a set of Dart, Iron Eagle cast iron heads due to durability concerns with aluminum (old school I guess). I called Dart to discuss and the tech said Dart really didn't make a head for the 396 application due to their head being designed for 4.3 minimum bore and he had concerns for valve to block clearance. This tech further recommended I consider using an Edelbrock head since they had more offerings for the 396 application..Huh. If I go with Edelbrock, I may do the top-end package if I can't determine my cam spec's. I'd rather use what I have (cam, TC& gear) and use the money elsewhere if possible.
How many manufacturer's tell you to go buy someone else's product?
When I hear things like "without breaking the bank" I think Brodix IKs. You can find them for under $1000 and they are a fantastic head. The 200s support over 600 HP easy. The 180s will probably work for a 350.
Look, picking parts is a process. If it were me, and it was, first pick your criteria. How are you going to drive it? What operating range?
Then, IMO, PICK THE CAM FIRST!! Get the cam card. Duration will determine your operating range, ramp will start to guide you toward heads. Ramp will be critical.
A modern camshaft like one produced by CompCams will utilize a very aggressive lobe design. The idea here is simple, cylinder heads used in racing classes often have to sacrifice low lift airflow (.100-.300) in order to get the very high flow at high lift numbers. They have found that through camshaft design that they can generate more hp through a pretty simple concept. Now many will talk until they're blue in the face that a good head has superior low and mid lift numbers and that is not entirely correct. SURPRISE!!!
If for example, you are going to use a 1.7 rocker to achieve .675 lift (with today's valve springs and valve train parts is not a big deal for a dual purpose engine) and you are utilizing a new CompCams solid roller you are wasting your time focusing on lift numbers and here's why. The aggressive lobe was designed to get the valve quickly (very, very quickly actually) into the .400 lift and higher range. You also sped the process up a bit by using a higher ratio rocker. The end result here is simple, you have a package that is designed to get the valve open quick, and stay open for as long as possible (when the valve spends most of it's measurable time at high lift, it's best to get your flow there). You also (since you read the above) have a well tuned exhaust tract that is aiding in the initial cylinder filling… In other words, IT'S ABOUT THE COMBINATION!!!
To boil it down I am a firm believer in the decision making process which is determined by the cam, then work toward the rockers, then the intake THEN you can pick a head. Without knowing all this other stuff, how do you know what head you need? The cam will set the tone for the rest of the motor. Pick your operational environment, pick the cam, look at all the specs, then we can discuss.
