Engine stalls
BangkokDean
Bangkok
I need to find out why the motor dies when hot? It starts right back up but will stall again after driving a short distance it will again start right up and if I hold the gas pedal when stopping with one foot on the brake pedal it seams to run?
It stalls using either systems Gasoline TPI or LPG injection. All sensors are new including the injectors and 02 sensor. The dizzy is used the coil is new.
minimum air set correctly? cold the idle speed is bumped up, keeping it from stalling. Timing set correctly? Must be set hot (cold has more spark advance so wait for it to go into closed loop) Depending on what prom you have, base timing will vary a little. I find it's easiest to just simply set it with the hei bypass disconnected and then double check with the engine running and a scanner hooked up to red total commanded advance and verify with a dial back
The hot idle is around 800rpm. How do you set the minimum air? Timing was set cold 6* with bypass wire disconnected. No one has a scanner over here.
OH, you didn't say about holding the brakes and giving gas....in the email, so most of my ideas are best kept for the future.....
what you maybe try doing is to get a torx bit into that idle adjustment screw on the TB, and open it up a tad,
have you wiped the throttle blades and passages out with solvent?? I use brake cleaner it tends to gather crap on it and not enough air for the IAC motor to overcome.....maybe pull it apart also, and clean the passages....
:clobbered:
:clobbered:
Gene
Actually I am not sure holding the gas and breaks actually worked. Driving in Bangkok is difficult with the traffic. I have been hesitant in driving the truck due to it stalling when hot and never knowing when it will stall. The distributor is probably the only part that is old and I would buy a new one if I knew where to buy it? It is not a typical HEI but computer controlled, do you know where I can order one, see picture.
There is no break cleaner available here but maybe lacquer thinner will do?
"try doing is to get a torx bit into that idle adjustment screw on the TB, and open it up a tad"
OK what is this and where is it located? Also TT recommended "minimum air set correctly?" How do you set this? It now idles 800 rpm hot.
That's a normal EST small cap HEI, nothing spectacular and yours looks very clean. Run it, it'll be just fine.
On the TB there's a 90 deg bent tang on the throttle linkage that sits against a screw @ idle. The TB casting has a rounded wider casting that you can see in the pic, the back side is open and has a torx screw inside, that's used to adjust the screw against the linkage tang. In the pic it's right above where your TV cable attaches.
To set minimum air you have to cycle the IAC closed but since you are having stall issues, just adjust the screw so the throttle blades open a little further and see what it doe.
You DO have the correct prom in it right? For an automatic and not a manual? IAC steps, stall saver etc. are different for a manual.
you can actually see the adjustment screw in this pic, right next to the cable
OH WAIT!!! You are using a speed density system right? Well, is your upper plenum a speed density one where the map sensor bolts to the back side of the manifold? If so your plenum may not have the IAC triangular hole between the throttle bores. You re using an older style throttle body that does have the opening. Please double check that!!
LEFT plenum is a SD unit...notice how it lacks that hole!!
Yes there is a screw to set the idle and it idles at 800 RPM hot.
I will have to remove the front section to see what type of Pentium I have.
I am not sure what a map sensor looks like. See pictures with the Pentium removed.
Idle screw, I turned it in a little, but what should it idle at hot in neutral?
[/URL]
This tube (A) has nothing connected?
Tube a is a timed vacuum source, cap it off. Also, make sure you set your tps in an acceptable range. The speed density systems simply check 0% tps on key on engine off but it will help to set it to about .54V
You have a non SD specific upper plenum, your map sensor must be located elsewhere. It's a black square sensor with a green colored metripack connector going into it and a vac hose.
TPS where is it located? I will try to locate the map sensor, is in on the Pentium or intake? Still don't know what a good idle is supposed to be in neutral?
Yes, tube A used to go to a fume recovery system valve, doubt you have one, it's under full vac all the time on my car/installs....so cap it off, I note that on the right/pass side of the TB, you supposed to have two vac source tubes coming out....one is larger and up top about 7/16 dia, the other is down lower and 3/8 diameter, the smaller one went to a PCV valve.....the larger one went to a valve cover, it's ported vac, coming in before the throttle blades, the PCV valve went on the other valve cover.....
the MAP sensor is a black plastic thing with 3 wires and a weather pac connector on it, and a vac line to main plenum vacuum, usually on one of the ports in the cut out of the rear pass/right side, you fined 2-3? holes in there for screwing in NPT vacuum nipples, one of them is only 1/8 stem and goes to the fuel pressure regulator nice and short hose, the other is 3/16-1/4 hose and goes to the MAP sensor, once again located close by on the firewall on my cars, but I can't recall where GM put it, especialy on an F body which is where your HEI version came from.....I was talking of the HEI like found in a C4 vette in my email.....sorry, I forgot about the F body version with the detached coil.....:nuts:
I saw in one of the pix above a loose wire/connector that looked as if it maybe go to the MAP sensor, hard to tell......MAP sensor is about 3" long with a mounting tab on each end, there maybe variations on that casting though....about 3/8 thick and 1.5" wide.....:bounce:
I suspect that if you hook this all up, and plug that port A, you will be running like a top at ~600 rpm idle, and happy as a clam....
This green wire?
"tube A used to go to a fume recovery system valve, doubt you have one, it's under full vac all the time on my car/installs....so cap it off"
OK I will cap it off.
I note that on the right/pass side of the TB, you supposed to have two vac source tubes coming out....one is larger and up top about 7/16 dia, the other is down lower and 3/8 diameter, the smaller one went to a PCV valve.....the larger one went to a valve cover.
I have those filled in (see picture)with the PCV connected on the left side intake, there is a port for it.
Your second picture above- the square connector is the IAC- idle air control and the flat 3 wire connector is the TPS. Make sure the internal passages around the IAC are clear and the valve on the end of it moves freely with the commands from the ECM.
Thanks Tim
OK, I can remove it and see if it moves freely but how can I tell that the ECM command moves it?
I still don't know what the MAP sensor looks like or where it is located?
The TPS is not a drive type device- it is the position sensor for the ECM. It gets a 5v reference from the ECM, and in turn sends a portion of that 5v back to the ECM to tell it how far the gas pedal is pushed.
Map sensor looks like this:
http://www.maperformance.com/gm-3-bar-map-sensor.htm
OK it is an old sensor located in the bottom rear of the Pentium. It has a green connector from the wire loom. Mine does not look like that one mine does not have a vacuum connector hose connected I guess my MAP gets vacuum directly from the Pentium so there is no hose connected to it, but it is difficult to see it.
Summit shows a different type MAP sensor for a 88-89 f body.
http://www.summitracing.com/dom/par.../1990/make/chevrolet/model/camaro?prefilter=1
Now will this sensor cause the motor to die and easily restart with both of my systems (gas or LPG) what is the effect if it is not working?
I did cap the vacuum port (A) but the engine still dies even on the highway at 60 mph. It dies mostly when slowing down but the highway bit is scary.
So until I find the problem I wont be driving the truck.
I did order a new Dizzy from JEGS, just in case the old dizzy is the problem.
Do you think I should also order a new MAP sensor also and which one?
Thanks, Dean
Your plenum is not set up for a bolt on map sensor, the pass side rear there are ports, one of them should connect to the MAP, the other is for the VRFPR and if there's a 3rd it's for the accy vacuum. The green single wire is from your EGR.
Here's a map sensor below the MSD coil
and a 2nd one above the brake booster (it's a 2 bar map for boost control)
Without the MAP sensor you will get an instant CEL, the engine will run but rough and crappy and may indeed die @ idle. Is your CEL on? Did you ever try to pull the codes after running the engine??
OK, found it now that I know what it looks like and where to look. I cant see the color of the connector due to the difficult location.
Please keep in mind that the motor runs just fine with both systems but dies all of a sudden and at all speeds. It will start right up and will seam fine for a while then it will stall again.
As for pulling codes how do you do that? My gauges are Dakota digital.
That looks like the oddest position for a MAP sensor, down next to the headers, and what are all those vacuum hoses doing there?? I can see one smaller hose to the map sensor, but I seeing larger ones also... why??
looks like some green wires going under that bracket, and for some reason the MAP sensor looks as if the mounting tab on the outer end was broken off....that's weird....
what I would do is get another sensor, and just let it hang off the port with a short hose to the plenum, and do what necessary to get the wires hooked up correctly.....
wonder if it's heat related?? too much heat for the poor sensor, that's certainly a funky location that I see no reason for it to be THERE.....:club::amazed:
