MYBAD79
Moderator
What should the wear pattern on the gear look like ? I have the shiny area a little towards the bottom, should it be centered on the gear ?
I am using a gasket under the dizzy, if I leave that off the gears would sit lower but then it will most likely leak... not ??
I've read somewhere NOT to use any gaskets under the dizzy.... ???
