Imo Apita
- Joined
- Feb 28, 2009
- Messages
- 244
Needs some help with some basic questions here.
Can't use the 350 block for a 383 build because of a chunk of cylinder wall missing.
Found a 400 4 bolt block on my local craigslist. Block only, nothing else, asking $250.
I understand that a 400 is a bolt in for a 350 so no issues there. However for the 350 I intended to use a 383 stroker kit with a 3.750 crank.
Can I use this crank in a 400?
From Hotrod forums:
So a 030 overbore on a 400 block with a 3.75 crank will give you 377 ci?
I sit necessary for steam holes to be drilled when using aluminum heads?
Bottom line is am I better of with a 377 (of 400) or a 383 (of a 350)?
If I can buy a 4 bolt 400 for the same $$ as a 350 with which one am I better of?
This is supposed to be a low budget build to replace my ailing L48.
From Hotrod forums:
350 and 400 blocks use different main journal diameters: 2.45 inches for the 350; 2.65 inches for the 400. However, the rod journal diameters are the same at 2.100 inches.
A 350 crank will fit in a 400 block with bearing spacers (available from speed equipment suppliers etc. for about $50). With a 4.125-inch bore and 3.75-inch stroke, this will produce 372 cubic inches, or 377 ci with a .030 overbore
