phantomjock
The chassis is disassembled. All componets are off. I am in the middle of POR-15 painting, so what next? (Suddenly, I feel like my sig)
Goal -- improve performance (Think -- Drag and Autocross). Do it incrementally to help distribute the costs over time.
The members of this forum have done a heap of work -- and I am building on their kind experience and sharing.
So - here is what I am thinking as a plan for the rear end on my C3:
A Multi-bar system, that will;
OBJECTIVES:
1. Keep the original Trailing Arms -- but modify:
1a. Do the Johnny Joint mod to them found here:
1b. Do the Twin Turbo Coil Over mod (the strut with shock mount as described here:
2. Add an upper link mount to the Trailing Arms similar to:
2a. Fabricate an upper Diff Mount - similar to the "Smart Struts" I have on the bottom of the Diff (or follow Stroker427s lead)
2b. Build the Links - 5/8 inch Heim Joints with jamnuts and tubes sized to get close to parallel:
3. Add a rear (Toe-Adjust) mount to the Trailing Arms (a la Stroker427):
3a. Fabricate a diff mount aft of the diff - maybe using the Upper Diff mount in 2a above:
3b. Build Toe adjust Arms
4. Relocate E-brake mount to top of Trailing Arms:
5. Design, build, and install half shaft safety loops
6. Design, build, and install drive shaft safety loop
Now, the incremental part:
7. Add a drag strut (optional) Not too expensive - may do the welding now and add bar later
8. Continue to use the monoleaf fiberglass spring, but mount shocks to new mounts
9. As time and money permits - upgrade to adjustable (single - or dual?) coil overs on the new shock mounts and ditch the Monoleaf
10. I don't think it will make a very good Boat Anchor - but might make a good spring for a DIY CROSSBOW!
I'm certain I'll have questions to add to this thread as I move along too.
Meanwhile, I anxiously await everyone's thoughts and comments before I take too wrong a turn!
As I have time I'll try and sketch up a pic or 2.
Also load some of the POR-15 progress/effort.
minimize camber change,
have adjustable toe-in,
improve opportunity to use wider tires/deeper offset wheels, and,
have adjustablity to ride response and ride height.
OBJECTIVES:
http://www.dragvette.com/irs_build_up.htm or, more like:
http://www.vettemod.com/forum/showthread.php?t=677&highlight=Trailing+Arm
