C3Vettes.net
Member
This tool makes coil spring installation an easy job.
I'd be interested to know why it's easy to use and I tried to look up the price. All I could see that that manufacturer made were strut compressors.
These easiest way to compress springs, for me so far, has been to chain my jack body to the frame, position the lifting pad of the jack arm, under the control arm (actually the ball joint nut) and jack it up. When the spring has a little compression it'll wedge a little sideways in the control tower. Then I reach into the sock absorper mounting hole at the top of the tower, take a heavy screwdriver and Hammer, and then bank the spring into place. The jack they completes the compression process. Pretty easy, but mucking around with the spring always makes me nervous.
What makes it different from other spring compressors?
