45 double flared non seamless
37 degree has a larger sealing surface for the same diameter tubing. 37 deg also called JIC or AN was developed for high pressure hydraulics (JIC) and widely used by the military (AN)
double flares are done because of 2 reasons. 1 the flare has some give and thus less prone to crack and 2 the most important, the lines are not seamless, as in there is a seam in the inside of the tubing. Create a flare surface on it and it will leak. Simply double flare it and the smooth outside becomes the sealing surface, presto...a perfect sealiong surface 45 deg flare
AN & JIC stuff commonly uses flare sleeves to absorb most of the distortion from the flare nut being tightened and trying to twist the flare
Don't mean to highjack this thread but is it much cheaper to make your own brake lines than it is to order them from say Classic Tube? I think there complete set comes to around $125.00 or so.
I have to raise the body anyway to do all the mounts so is it more cost effective to go with the complete set?
I have a double flaring set, and so just buy two 5' brake lines and couple them together, cut/flare as needed at the m/cyl end nice and easy....been that way on the vette for years now, no issues....easy install too, I thought....even did a mid year that way some time ago...no issues....
these guys claiming you have to remove the body to do one are nutz....
:bonkers:
:bonkers:
Why not couple the two 5' lines using a compression fitting, no flaring required.
Replacing brake lines without removing the body is a no brainer, but fuel lines are another story. Been there-done that.
Interesting info on the flaring angles. I have used the flaring tool rented out at my local Advanced Auto successfully, but never knew what angle it produced. I have since bought a double flaring tool from Harbor freight, but have not needed to use it, and still don't know what angle it is made to produce. I wonder if one angle will conform to fit the other, once drawn tight in a fitting?
